- Thank you received: 279
firstly, Congrats on getting the old girl up and running and driving. your perseverance and patience has paid off.
after reading your last post, just curious if anyone can shed light on the oil pressure safety you find in the governor? Would this impact the fuel delivery problem you were experiencing when you were trying to bleed the #1 injector? i can't see the engine oil pump creating that much pressure while cranking, all of my electric start engines that have the old style bordon tube oil pressure gauges don't register pressure until after the engine catches and begins to run.
how did they engineer the governor to have a shutdown related to oil pressure that didn't prevent the engine from delivering fuel for a start up condition? is it because the spring pressure of the governor is pulling the rack to full fuel until the weights start spinning and move the rack back to the desired engine speed as set by the control linkage?
Hi, gvanhouten.
I am very pleased for you that she got up and moved for you with no further issues. They were and are one tough machine. Cat have made a few duds over the years, although less, I think, than pretty much any other name in the game, but I also think that the D9Gs, especially the later ones, were and are one of their brighter stars.
As Gauntjoh said, you have pretty much repaid for all the help you received here by joining ACMOC and taking a whole bunch of people on your journey with you 'cos, in the process, you have surfaced a LOTTT of knowledge and a LOTTT of ideas that will have been seen by far more people than just those who have posted in this discussion. THAT is what this BB is all about.
Re the headline of this post and as mentioned previously, we have a show coming up at Santa Margarita Ranch, Santa Margarita, CA, on Memorial Day Weekend, May 22 to 24, 2020. If you can make it here, I would be honored to shake your hand and buy you lunch.
And just so that I not seen as being biased, there is another show at another venue - although likely with a lot of the same suspects - at the Tulare Agricenter, April 17 to 19.
Both of these shows will have working displays, grand parades, etc., but the ranch one also has military hardware and warbirds, the old Disneyland steam trains running and a commeorative service at midday each of the 3 days with the warbirds doing a flypast during the service.
I suspect that there will be a fair bit more publicity on here for both before the respective events. You would also likely be able to meet a few more of the people who have posted in and/or followed your journey.
The oil pressure control is part of the decelerator function.
Thanks for the diagram and explanation OM. That relates perfectly to the symptoms George explained.
Good job George. What are your thoughts on what factor(s) enabled it to start and run? Based on what you wrote, I'm heavily in favor of the extra oil in the cylinders providing a better compression ratio to increase temperatures. How much do you estimate you inserted per cylinder?
P.O. Box 9301
Peoria, IL 61612
(309) 691-5002
cat@acmoc.org
- Chris R
- Jason N
