UPDATE:
I started up with the loader in the cold shop. Did not start right off with the glow plugs. Needed a little squirt of ether. Just shortly after starting the radiator pressure relief valve started spitting radiator coolant. I checked the level of the coolant prior to starting and it was visible just below the cap and the vent on the head had no air in it just coolant. While the tractor was running, I unscrewed the radiator cap and there was a lot of bubbling. Head gasket was my assessment of the problem. I was also getting a bit of a miss, not sure exactly what cylinder. This is the first time that I have ever heard a miss in the engine. It was about 20 F in the shop. I pulled the head with the assumption that the bubbling in the radiator was a sure sign of that being the problem. After sleeping on it, it could also be a seal on the pre combustion chambers. Head is off and I have a few videos of the condition of the head and block with the gasket still on it. Just for reference I did replace the glow plugs, pre-combustion chamber seals and o rings last summer. I would be grateful if you guys could look the videos over and give me your assessment. There are a few seals that look a little suspect as well as a few of the brass sleeves that insert in them that look like during the last installation might have gotten beat up. I don't know when/if this head was ever replaced or any history on the engine. The stamp on the head is 7F8308 and the stamp on the head gasket is a 4F2789 VICTOR.
Here is the video of the Block with the head gasket on it just as it looked after head removal:
Here is the video of the head:
Here is the video of the head gasket:
I will be ordering a new gasket.
Will it come with the seals or are they separate part numbers?
Based on what you see and have experienced, would it be recommended for this head to be gone thru and resurfaced?
Do they ever warp?
Can you tell from looking at the face of the head if there was leakage at the precombustion chambers?
There is still cross hatching in the cylinders. I am assuming that the coolant in the 4 cylinder got in there when I pulled the head....it was tilted that way when I lifted it out with my a frame hoist. I have many pictures if they would be useful to see. I also noticed while removing the head nuts that they were not all equally tight. I would love to read your insight on this project of mine.
