- Thank you received: 620
Yea, the water pressure gauge should be up in the yellow. Check the relieve valve on top of the radiator, they tend to not seat and weep also.
Yea I believe a smaller ferrule and you have to have a threaded adapter into the tank. The Cat sending units had a plastic outer housing/coating that the ferrule would seal on.
do not recall seeing a water pressure gauge with that style protective covering, they were usually a black nylon/plastic coating as said above.
From memory the ferrule either only seals on the tube itself or may seal over the Cat style protection layer in there as well as said by RomeKG--its been too long ago now.
Maybe with that woven style protection layer you have to change fittings so as to seal on the copper tube only.
That ferrule type fitting system is usually known as "petrol fittings"
Be aware that later on again these colour graduated gauges were done away with as they caused more problems than enough with operators mis-interpreting what they were telling them.
Scan below is from a D9 66A 1-up grey OMI.
Hi, Misterskill.
Good to see her doing what she was made to do - and LOVE those big clouds of the ubiqitous but politically incorrect black smoke.
Thanks for sharing.
P.O. Box 9301
Peoria, IL 61612
(309) 691-5002
cat@acmoc.org
- Chris R
- Jason N
