- Thank you received: 620
Da-DaDaDa-Da, "Shake hands with danger" lolI approve of that milk crate to prop the blade up - probably overkill but better safe than sorry ; )
Broken track roller bolts are always a challenge.
But it can be done!
I have had success in drilling a smallish hole through the broken bolt first. Get the oxy and cut from the hole out to the edge of the thread both ways ( ie 180 deg apart ) then get a punch/chisel and knock the halves in till they fall through. Sounds difficult but it can be done.
If you have access to a magnetic based drill then life might be easier.
Good Luck
Cheers djcat.
P.O. Box 9301
Peoria, IL 61612
(309) 691-5002
cat@acmoc.org
- Chris R
- Jason N
