- Thank you received: 21
Maybe someone had overheating problems and tried to fix by removing one thermostat. Can be counter productive allowing coolant to flow too quickly in some aplications.
Hi, Misterskill.
WoooooHoooooooo!!!!!!!!!!!!!!! No wonder the poor girl was raising a sweat. I suspect she has been run on a steady diet of dirty water and no corrosion inhibitor for many a long year.
A good, straight, long length of steel packing case strap might help in cleaning out those tubes. There is a LOTTTTT of crud in there.
Hi Ms,
well, that is up there for the most clogged tubes I have come across, the old girl will thank you for some cooler coolant by working hard for longer.
Scan below may help with T/Frame Alignment.
There are shims inside the Outer Bearing Housing Cap to centralise the T/Frame on these--see Service Manual and Parts Book.
Hi, Misterskill.
Quote:
"Valentines day = Hot date with a radiator and a band-saw blade."
Unquote.
For the benefit of our topside readers, what kind of 'hot' are you expecting on Valentine's Day in your part of the world? Maybe around 42 - 45 degrees C.?
MS, now that your getting to the final stages of reviving the D9 and you’ve said the famous Cat quote “it’s turned out to be a bigger job than expected.”
You got any plans of reviving another relic after this one is finished? We all sure have enjoyed fallowing your frustrations and admiring your progress. We’re gonna be lost when your finished. So please continue to keep your eye on another project for your followers.
Bit of an update. The flush and new pressure relief valve made a small difference in that it would cool down a lot quicker then before, however after about 2 hours it was still getting hot. Right, top tank off to have a look inside. What a job, to access the front row of tank bolts the rad has to come out. Couldn't get it past the fan crossbrace so had to loosn the cowling and slide that back but got it enough to get at at them.
I think i may have found my problem.....
Also noticed a bit of damage to the sprocket. Have to do a bit of research on it but i'm thinking the furthest back roller isn't running it onto the sproket straight. Not sure yet, I'll fix the rad first, then deal with it.
P.O. Box 9301
Peoria, IL 61612
(309) 691-5002
cat@acmoc.org
- Chris R
- Jason N
