- Thank you received: 19
Wowza.... some serious dirt in there..... got clean her out so she can start to use those fins for some cooling.... Great job on getting her straightened out... I know first hand these big girls need a lot of love.... I ran my d9g yesterday and she started getting a little hot... I will do a couple things to her as well... Your sprocket teeth look a little straight and one is missing a chunk of metal out of it.... You know that took a bite out of her to do that.... Might need to replace the sprockets... But one thing at a time... Been there done that.... But boy when she works she can work.... It is worth it anyway..... Cheers and keep up the good work....
Worn "snakey" rails will chip the sprockets out when turning sharp.
Man, if that's what the radiator looks like, what's in the water jackets?!
The water pressure should have been close to the yellow.
Do you have a fuel shut off valve for the starting engine?
Yeah, it leaked and the replacement from caterpillar was rather expensive, so i have a motorbike fuel tap screwed straight into the bottom of the pony tank. I just have to reach around behind to turn it on and off.
I picked up a new fuel shutoff valve from Cat for my D2 - it's the one that sits next to the pinion control levers on the left side. That might be an approximation for your D9 valve on the dash. It is just a valve with an inlet NPT fitting at the back, and an "olive" connection on the top side that goes up to the carb
P.O. Box 9301
Peoria, IL 61612
(309) 691-5002
cat@acmoc.org
- Chris R
- Jason N
