- Thank you received: 21
That's a nice first pick. They were one of the best dozers that Cat ever produced. They were usually cannabalized for parts when parked. Was it a station machine in the recent past or at a quarry?
Good job on getting it running.
I hope so! new gauges, drained the fuel system, changed all the filters, New diesel, cleaned the points and the pony motor started up straight away (however needle and seat and gone so fuel control is done with the tap at the top). Cracked an injector line bled the fuel line and off she went!
It was brought up here in the 70's or early 80s for opal mining. Moved a lot of dirt in it's time but it seems to have been well maintained. Had a few bits robbed (gauges and some air cleaner bases that seem to be as rare as hen's teeth) but apart from that surprisingly in tact. Was parked up about 7 years ago and i found it at the start of this year and had to have it.
Washed the final drives on the weekend (no metal!) and refilled with new oil, did the engine oil, topped up the recoil spring and started on the track adjustment before we ran out of grease and daylight haha
Goes back and forward no worries, decelerator works, blade is very rough and needs the bottom half re-skinned, but goes up and down (tilts too, but that ram seal is shot). rippers are alright and move well.
I can turn if i pull the steering clutch in and press the corresponding brake but i'm not sure if the clutches are working 100%. If you pull the clutches they "spring back" i figure this is a good sign.
If i put it in gear with both clutches engaged the tractor goes forward, is this correct? i'm hearing conflicting opinions on this.
P.O. Box 9301
Peoria, IL 61612
(309) 691-5002
cat@acmoc.org
- Chris R
- Jason N
