- Thank you received: 21
Hi, Misterskill.
Man, yer gotta LOVE innovation.
Nah. You don't want a D2. Ev'rybody - and their dog - has a D2. How many people do you see on here with a D9G dozer with a multi-shank ripper?????????
Keeps the rear end cool and good ventilation when gas pressure builds up! lolHave a look at this for the latest in welding comfort! there are probably 4 or 5 strategically stashed around the yard.
Fun? is that what it's called. I caught myself the other day, whilst once again starting the excavator to lift something, (or belting something with the 12lbs sledge) muttering "I should have bought a d2..."
Alas we soldier on! Go hard or go home
2 more rams and hoses getting done on the KATO tomorrow so that's another job out of the way. Then my off-sider is away on holiday again in march so I'm off to try and make a bit of extra cash and keep the whole project going
Well, back into it. Main ram seals done on the excavator so back into the old rig
Track split and cylinder out. Clean it up tomorrow, then send the seals off to get replacements.
Also found a picture of it working back in the old days. 1967, she would have been a flash rig back then!
Thats a neat picture of her back in the day. Was she a opal miner from new?
Cheers
Billy
Hi Misterskill,
sadly, it looks like you missed removing the T/C Scav. Pump before removing the entire T/C assembly from the engine.
It is not unknown for the T/C to drop down onto the scav. pump drive gear and bend the scav. pump input shaft.
The T/C scav. pump should be removed before the T/C assembly is removed from the engine and re-fitted after the assembly is back in place on the engine.
Sorry for the heads up now, I hope it is fine. If the shaft is bent and not noticed then a rotating bending fatigue failure of the shaft usually results in carnage in the T/C housing when the scav. pump gear gets loose.
P.O. Box 9301
Peoria, IL 61612
(309) 691-5002
cat@acmoc.org
- Chris R
- Jason N
