- Thank you received: 21
Service manual shows the transfer gear case cover being lifted from the case. Does show a three point lifting arrangement which I suspect is required to keep things aligned to slip off the input shaft.
I see you have already removed the 3 large cover dowels.
The cover, along with the pinion and its drive gear, should lift straight up--the trans. output splined shaft and input transfer gear should remain.
You may need to keep turning the pinion for the rollers to slide up thru the pinion shaft inner bearing outer race--it is fairly important that the whole cover and pinion needs to be very square to achieve this.
From memory, there can be an issue with the part number suppression of the outer large pinion bearing race.
The NPR gives a few machine application options and this decides which new outer race is needed.
In my day at The Dealer the first machine listed was a Grader and the race here does not use the thrust lip at one end of the race--it is a straight thru bore.
The lip is what takes the roller end thrust of the pinion in the Reverse travel direction--yes--Cat successfully apply end thrust to these roller bearings in D6,7,8,9 tractors, contrary to popular opinion that roller bearings will not survive when end thrust is applied.
If the non lipped race is fitted by error it has to be welded to shrink it for removal and so cannot be credited back--lots of $$$'s lost unless you can convince the supplier they erred.
Have been involved when clients had noise issues with pinion in Reverse after the fact.
To be honest I do not know how they set the pinion depth--should be held back against the lip with a bolt thru the case cover, when adjusting the tooth back lash with the bevel gear.
Looking at the parts book cross section I don't see any reason it should be that difficult to remove the plate with the bevel pinion. I'm wondering if it is hung up on worn splines??
P.O. Box 9301
Peoria, IL 61612
(309) 691-5002
cat@acmoc.org
- Chris R
- Jason N
