- Thank you received: 18
Neat old tractor, would of been massive in its time and still is a big dozer. Beauty of the climate up there is corrosion should be minimal, not like a lot of dozers from wetter areas that suffer badly from corrosion when left outside to rot. Still quite a few 8's and 9's left sitting around in opal fields from what I hear. Most probably parked for a reason however this one appears a near tractor and fired up no worries! Good luck with it and keep us posted, a great era of dozer.
Cheers
Billy
This one had a ticking noise in reverse apparently, so far so good though... the price i got it for i was expecting at least one major repair.
Big enough for me i reckon, found an old Komatsu D455A the other day. Everything is big and heavy on mine, let alone something like that...
Getting pretty thin on the ground these days. I think they all went to Mintabie when that took off and most didn't make it back.
So we loosened the track bleed valve and a little bit of grease came out, not much pressure. so we removed the valve, pumped a bit it in to watch it was going in, then put them back in and started filling it up.
We ended up assisting it a bit with a jack between the frame and the idler brackets. got about 50mm on one side (2inches) before it stopped moving as freely. then onto the other side, heap of grease and nothing. then it starts leaking oil? thinking it might the "track adjuster seal" i keep hearing so much about and hoping it's nothing more serious. it has been leaking for a while by the look of it. We were looking at trying and jack it apart and then fill with grease and see how it holds up.
Thanks for your help fellas, it's much appreciated. Get this old girl fixed up and back into it in no time!
Looks like your making good progress. Are you going to pull the tranny out for the reverse issue?
P.O. Box 9301
Peoria, IL 61612
(309) 691-5002
cat@acmoc.org
- Chris R
- Jason N
