- Thank you received: 3
Usual location, upper LH corner rear of the steering clutch housing and left rear of the engine about behind the magneto.
What did you find for a s/n?
For sure you will want to roll the engine over before engaging starter.
Seems it still has remnants of the pony motor start. The lever is most likely the compression release. Horizontal is start, pull down vertical is run.
Lever to the right of what? Just to the right of the right brake pedal is the forward/reverse lever. To the right of that is the gear selector.
P.O. Box 9301
Peoria, IL 61612
(309) 691-5002
cat@acmoc.org
- Chris R
- Jason N
