- Thank you received: 620
"You put your hand over the open injector hole!?" "You know what have to say about that"
I'm definitely not smarter than Mike, but 6psi at the gauge port is plenty. The way to tackle this is start at the beginning of the "chain" and work your way forward, proving that you have adequate flow. Start with the inlet from the tank into the transfer pump. Disconnect it, and let it flow for a good minute and fill up a bucket. If it slows down after a bit, you have a blockage somewhere upstream. Once that's good, then go to the top of the fuel filter tower. Again get good flow out of the two bleeders for a good minute - don't shortchange it. You want to see good sustained flow. Do the same for the pump bleeders and finally the injectors. Once you have done all of that, then you know your fuel system is ok. If you skip anything, then the fuel system is not proven.
Once you have it bled, then as Mike says, you can tow-start it. The benefit of this is that you can get it cranking faster than the pony will crank it and if you have a low compression, the extra rpm can help overcome that. But before towing, run it with the pony under compression for a good five minutes to get heat into it. Don't turn on the fuel during this time, and make sure the governor is firmly closed.
P.O. Box 9301
Peoria, IL 61612
(309) 691-5002
cat@acmoc.org
- Chris R
- Jason N
