- Thank you received: 0
If you havent felt the detent then you for sure dont have the fuel on. Keep checking, you have the problem solved. Just need to find out where it is stuck.
Rack will still move some with it shutoff.
It's spring forward and governor centrifugal weight back.
there is not a detent on these it is simply an adjustable spring loaded Stop Plunger- Big Screw, that is adjusted to set the Low Idle speed.
Here is what I believe happens--I stand to be corrected--When the Operators Gov. Control lever is moved Forward to the Stop position the rack moves Forwards also and the internal lever pushes the plunger in against its spring to take the rack Forwards to a No Fuel position. In this position the rack should be solidly held Forwards by the linkage system.
In the Fuel On position the rack would be Rearwards and held there by the now stretched Gov. Spring awaiting the governor weights to push it back to a lower fuel (speed) condition.
See scans below.
WELL NOW seems I have again lost my ability to post more pics.
SORRY boys the last upgrade must have defaulted the system I guess.
P.O. Box 9301
Peoria, IL 61612
(309) 691-5002
cat@acmoc.org
- Chris R
- Jason N
