- Thank you received: 0
until I can post pix again, fuel leakage past the Inj Pump Plungers still can be be minimal at the troughs in a worn Inj. Pump plunger and barrel--P & B.
Wear takes place by dirty fuel eroding the plunger at the helix and the barrel bore at the fuel bypass port.
There is a a possibility of excess leakage if the entire length of the bore and plunger are scored at a land that helps stop this occurring.
In the stop position, transfer pump pressure fuel can be seen as spurts as the plunger rises, due to restriction of the trapped fuel above the plunger exiting the bypass port and so creates a visible spurt when the injection line is loose or removed from the Inj. pump P & B Assembly.
Wasted half an hour trying to find where I posted pix in the past many times over from a Service Manual explaining all this clearly.
It moves all the way forward and back.
Edit: Watching Squatch install the pumps on 5J1113, after everything was installed, he moved the rack forward and backwards and it appeared to be spring loaded back through the governor spring. I don't recall it springing back, but I'm not sure this is relevant to not starting. I think it's worth popping off the pump cover again and pulling the governor cover.
The fuel pressure in the tower is very important and if the fuel pressure gauge on the machine isn't working then definitely hook up a working gauge, the pressure is not super high, I think it's less than 10 pounds, but it must be there.
You will see a 1,000 old threads here from people asking why their old Cat won't start and low fuel tower pressure is often the cause, there is a one way valve where the fuel line from the tank enters the tower and the spring that holds that valve usually get's tired and needs re-stretching or replacing, or the little one way valve itself get's crud stuck in it preventing pressure from building. Definitely investigate that area.
I've found a old Cat will run with low fuel tower pressure, but it usually will not start too easily, or will not start at all.
Sounds like your buddy is a hard man on machines, he sounds like my neighbor, 3rd generation farmer but doesn't even own a grease gun, bottle of oil or a set of tools, he runs his tractor out of fuel regularly yet can't remember how to bleed the system. Mechanics love old fleas like him, because the repair bills always have a lot of zero's!!
P.O. Box 9301
Peoria, IL 61612
(309) 691-5002
cat@acmoc.org
- Chris R
- Jason N
