D2 5J8882 Can low compression be caused by coolant leak
Thank you received: 90
4 years 5 months ago #214648
by bruce oz
hello ,i wouldn't be pulling anything apart until your cleaned all the fuel system out and bleed the system back up ,maybe just a old dry fuel has blocked the line some where ,as you say it did run , bruce
4 years 5 months ago #214667
by Whitedog
Different part number for the D2 injector removal tool, 4B9917, but it looks like it might be the same as the D4 tool, Florin has them.
Thanks, Mike but I have enough tools I only needed once. Lol
4 years 5 months ago #214668
by Whitedog
Bruce, what all do suggest for cleaning out the fuel system? Filter housing was drained and bled, high pressure lines at the injectors. Well, I guess that's it.
I should note that the fuel is questionable at best. But so far I haven't mentioned it because people here have said that these engines are not picky at all about fuel.
4 years 5 months ago #214673
by bruce oz
hello ,did you do the fuel tank line / and did it built fuel pressure back up when you bleed the system ? bruce
Thank you received: 26
4 years 5 months ago #214707
by Jack
IF you pull the injectors, try to find a fitting to go into the precup where the injector was and do a pressure bleed down test. They can tell you a lot sometimes you can even hear the sir whistling into the crankcase or out a manifold...
Thank you received: 49
4 years 5 months ago #214713
by kracked1
As said before, try some ether and see if it will fire on that. That will tell if fuel or hard parts. I fought a 212 that I KNEW wasnt stuck in fuel off position. I redid everything many times over. Finally I got pissed and yanked hard enough to break stuff and it tripped the shutoff and it started right up. Same as you it had run before and never stuck. Hasnt stuck since. And the rack was moving in the pump and all the plungers were going up and down also.
4 years 5 months ago #214715
by Whitedog
So it fires and smokes on ether, but won't stay running. Now I'm wondering how he shut it off when he put it on the trailer. I haven't thought about how to shut it off - something that is a big no-no. If I got it started, how to shut it off. I'm guessing you just push the throttle lever all the way forward. I know I've pushed the lever forward, but I don't feel a detent. Should I feel a definite click when going to shut off position?
I've been watching Squatch253 rebuild his 5J1113 but I'm not up to the fuel system yet. I may need to jump ahead. Great idea.
4 years 5 months ago #214716
by Whitedog
Just figured out how a coolant leak could cause low compression.
Cracked pre-cups. Combustion passes through the crack, pressuring the coolant system causing it to leak.
Now, why am I not worried about this being the issue we are having? If it was cracked enough to cause compression low enough to not start, 1: it would show in the radiator neck with the cap off and B: coolant would be in the oil from leaking into the cylinder, past the rings and into the pan.
Since neither of these things are happening, that's not the issue.
Thank you received: 187
4 years 5 months ago #214719
by Mike Meyer
Have a flat piece of wood handy to put over the air cleaner or inlet manifold if the engine takes off on you.
4 years 5 months ago #214722
by kracked1
If you havent felt the detent then you for sure dont have the fuel on. Keep checking, you have the problem solved. Just need to find out where it is stuck.
Time to create page: 0.381 seconds
