- Thank you received: 5
While is was digging up valve adjustment info for another poster I was reminded that you would need the same for the D9. It's a simplified version that doesn't require many crankshaft revolutions.
6-cyl, 1,5,3,6,2,4 firing order
Position #1 @ TDC
Adj Intake #1,2,4 Exh #1,3,5
Rotate 360 deg to #6 @ TDC
Adj Intake #3,5,6 Exh #2,4,6
Position #1 @ TDC
All the old Caterpillar engines I am familiar with have a 6 bolt symmetric pattern crankshaft flange to attach the flywheel. There is only a chisel mark on the crankshaft flange to match to a similar flywheel mark, but nothing preventing bolting it on wrong.
So 5 out of 6 chances to get it wrong, missing both correct numbers AND lines..........3/6 to miss the TC lines completely and 2/6 to get that right but with wrong cylinder numbers as you have found........Only 1 chance out of 6 to get it on with both TC lines and numbers correct.
Hope this discovery leads to great things for you!
The shortest route to success would be to observe the #1 rod at TDC, and the valves to not be rocking, to quickly establish TDC on #1 - everything else will follow from there, whether it's determining that the valve train is timed correctly, the injection cam is timed correctly, and from there the valve lash and lifter height. Looking forward to seeing that first start video George! : )
P.O. Box 9301
Peoria, IL 61612
(309) 691-5002
cat@acmoc.org
- Chris R
- Jason N
