- Thank you received: 57
Its nearly 30 years since I had a 225 SA, at the finish I was having lots of problems with it, after spending large amounts of money on field servicemen without much success, I bit the bullet and bought a new 325L
You may find the slow boom lift could be one or a multitude of problems, lack of signal pressure to the pumps to open the swash plates etc, could be only running on one pump instead of two for that function, you could have one pump on the way out. It will take a good man to diagnose issues on a 225, with no computer to help him it is a very specialist task to trouble shoot and eliminate. To fix all the things you have mentioned it would not be too hard to spend $20,000 plus.
i don't wish to poor cold water on things, just suggesting think carefully about how far you go and if not getting results is the tractor past it and time to step up to something later and in better order.
Regards, Wombat
Before you chastize yourself too much better change the oil and see if it fixes the problemEddie,
I have been using the 30W from the get-go and maybe I created the boom lift problem on my own by using the incorrect oil. What a dumbass...
I would also like to thank you Eddie for the great information. One thing though, as mentioned before in my 305CR operators manual, straight 30W oil is allowed for temperatures from 10-50c. What you have said about the issues using thicker oil in the piston pumps and also what I have been taught and experienced about the issue why would Cat have 30W as being acceptable.
I did ask you about the oil but I thought Cat systems must be engineered to take the 30W given it is in the manual for the 305 and at
www.catfluidselector.com/us/en_US/equipm...excavators_EFt8Pe1Om
for your 225.
Regards
Phil
P.O. Box 9301
Peoria, IL 61612
(309) 691-5002
cat@acmoc.org
- Chris R
- Jason N
