- Thank you received: 63
Having owned numerous excavators my advice is that you can't afford to restore these machines with the first generation of moderen hydraulic systems with $150/ hour service calls for a mechanic and service truck. Cat isn't interested in serving older machines any more so parts request come up obsolete or the prices have been dramatally increased, thanks to the MBA's of this world. You might consider selling the equipment and using the funds to hiering a contractor to do the work or renting a newer machine and doing the work yourself.
Thanks for pointing that out Eddie. My operators manual for my 305CR lists a straight 30W viscosity oil for use in temperatures 10 to 50 degrees C which does not make sense given the type of hydraulic pump.Hi Team,
in my experience 10W Hydraulic oil should be used for all temperatures in these axial piston pump systems as detailed per my school notes photocopy of the Lubrication and Maintenance Guide, Form No GEG02140-02.
In cold weather the axial piston pump plunger/piston shoes have been known to pull off the pistons in these and other applications if the Pre-Operation Warm-up Procedure and Warnings for the Hydraulic system oil, as detailed in the Operator's Guide, Form No SEBU5339 are not adhered to.
I would prefer to fix what I have in both the D6C (10K401) and the 225LC (51U2607).
My 305CR is non computerized but still has an overly complex electrical system. I still think your best bet would be to talk to a local hydraulic service shop. Does not need to be a huge shop.
If you sell the machine you have to find a replacement, in Australia that size machine would set you back at least $50,000 depending on how new you want to go. I don't know what a 200 series would be worth in the US but most machines seem to be very cheap over there at least compared to here.
If it was me I would be looking at the machine condition as a unit; If the engine is good, pivot pins and bushes are good, walking gear is good (or at least still has some life left in it), little or no rust then I would keep it and spend the money to solve the problem however if any of those items are not in good condtion then fixing the hydraulics will only be the start.
I also don't know about the availabilty of parts for that series direct from Cat but there are numerous wreckers and spare parts dealers that should be able to help out.
Unfortunately it will take some money to find the cause of the issue. Perhaps someone in you local ACMOC chapter could help out either directly or by passing on your details to some one who can.
A couple of other things I would try though, and I don't know how easy or difficult it woule be to do.
1) Run the machine until the fault occurs and swap the pilot lines from the lift valve to another control valve, If the problem moves with the hoses then the pilot control valve is fine.
2) Run the machine until the fault occurs and swap the hoses from the bucket to the boom lift and vise versa. If the lift speed is still slow then the valviing is not at fault. If everything is hard piped to the valving then this might be difficult to achieve. I wouild also imagine that the other functions would have a lower flow rate so it would naturally be slower.
Keep in mind the oil will most likely be very hot.
Regards
Phil
P.O. Box 9301
Peoria, IL 61612
(309) 691-5002
cat@acmoc.org
- Chris R
- Jason N
