- Thank you received: 3
Nice Job Mike!
I noticed the water temp was way low on the first video, on the next 2 videos I see the cardboard blocking the radiator and watched to see the water temp up in the operating range.
Nice troubleshooting and process of elimination!
Jeff
Toby has recently put this #34 up for his D3400 Engine.
I thoroughly recommend that every one should watch ALL of Toby's Tutorials on his D3400 engine as they are full of good practice and data.
Toby's tutorials are excellent for learning how or why on Cat machines.
D311 lifter setting height on engine is :-1.736" at TDC for the relevant cylinder.
This will give you an Injection Timing in Degrees of 12Deg. BTDC (Before Top Dead Center)
These lifter settings have a check tolerance of +/- 0.002" so I would usually set the lifter setting minus 0.001" of the spec. :- ie at 1.735" for this measurement specification setting, which has effectively set the injection timing in an advanced condition measurement--this will aid cold starting ability.
P.O. Box 9301
Peoria, IL 61612
(309) 691-5002
cat@acmoc.org
- Chris R
- Jason N
