TROUBLESHOOTING, Site & Sound Video of D311 Genny EXHAUST under load
Thank you received: 67
4 years 4 months ago #217512
by kittyman1
-is the engine consuming any oil from engine crankcase?
-all fluid levels holding?
-just wondering if there could be other mechanical issues as well? (sticky rings, worn valve guides etc)
-have you checked valve lash? and is it holding?
-checking injectors and fuel injection pump first to verify everything within spec as you're doing is the correct way to proceed:clap2:
-a process of elimination i suppose..
Thank you received: 43
4 years 3 months ago #218562
by ag-mike
Excersizsing it 2day with a 13 & 19k load. Runs and sounds better after every hour running.
Thank you received: 620
4 years 3 months ago #218568
by ag-mike
Damn! No wonder its 90 degrees here in Ohio today! lol
good 1!
it was pointing east!
4 years 3 months ago #218813
by ag-mike
Changed all 4 fuel nozzles/valves today, runs alot better with clear and complete burn exhaust.
Thank you received: 341
4 years 3 months ago #218821
by edb
Hi Mike,
now your getting somewhere--nozzles look somewhat carboned up on the tips--one or two appear wet but that can occur when you remove them--for sure a nozzle tester would be the way to tell for sure.
4 years 3 months ago #218823
by ag-mike
Hi Mike,
Gonna adjust the valves and check plunger measurements next. Its sounding better and better every time i run it with load.
4 years 3 months ago #218827
by kittyman1
-really sounding better Mike....and checking the valve lash is great too...it tells a lot of the engines condition..
