TROUBLESHOOTING, Site & Sound Video of D311 Genny EXHAUST under load
Thank you received: 43
4 years 4 months ago #217133
by ag-mike
Could also be firing off leaked lube oil instead of diesel fuel which kind of goes along with the blue smoke.
Will pull e-manifold 1st. What can be done about stuck rings????
4 years 4 months ago #217145
by ag-mike
70* 2day, 3 minute vid showing no.3 the worst, running without manifold.
At first I have the engine at a higher rpm, then i go round and back throttle down towards idle. Thats when the most smoke is seen. No. 3 the worst, then no.4. None of the ports were wet.
4 years 4 months ago #217147
by ag-mike
Thank you received: 409
4 years 4 months ago #217158
That puff when you idled down almost looked like valve seal leakage as you'd see on a gas engine, but that happens partly due to the vacuum when closing the gas engine throttle, which you don't have here. What's the liquid that appears to be coming from the stud holes?
4 years 4 months ago #217167
by ag-mike
Its oil best i can tell coming from the threaded bores.(engine was warmed up)
Just minimal amount from the static area beyond the end of stud i assume.
Thank you received: 42
4 years 4 months ago #217180
by restore49
Your not temped to put a load on and fill the tank and go have a long lunch? How long has it been since a hard exercise? Bob
4 years 4 months ago #217186
by ag-mike
How oily are the exhaust passages?
By sight they all looked dry black soot, no.3 had the most dry looking residue compare to the others. I didn't rub my finger in the ports, 2me the ports kinda thinking/looked running rich, this black look could be from running it sunday 8 hrs with 15kw load on it. Didn't have black smoke out the exhaust sunday.
edit, tomorrow i'll rub my finger in the port residue and see if its wet. I looked hard up into the passages, they looked dry. I'm gonna go towards the injector capsules next.
Time to create page: 0.186 seconds
