- Thank you received: 67
Hi OM,
yes indeed, I have no explanation or experience of such reported large volume of oil loss from the engine--leaking lip seals in pumps, or piston ring seals for the crank usually take some time to transfer large volumes oil--I guess unless they are missing ???
Can only think machine was not level when the oil was refilled and checked--not sure now if the engine oil was filled by volume or dip stick checks--I feel there could be some cloud over George's explanations for some issues reported.
Now he has the machine home I think these issues need to be re-checked so as to rule out any possible observation errors.
Its easy to do a re-test and then formulate a plan of attack for any issues found to be still evident.
Would be hesitant to go ripping things apart yet without positive proof--my thoughts.
Hi OM,
Maybe this one is more readable...
TO-2 is considered an obsolete spec. Current is TO-4.
The only way I'd recommend the TO-2 is that we are unsure of the operation of the unit with possible engine oil contamination and you may wind up dumping that oil for repair and replacement.
P.O. Box 9301
Peoria, IL 61612
(309) 691-5002
cat@acmoc.org
- Chris R
- Jason N
