- Thank you received: 46
3F6697 bolts are $4.44 ea. at Regal, $10.79 OEM list.
I've used shim stock before to take up the slop, it doesn't always work. I would try a mix of metric and standard sockets to find one that fits best.
Decided to stop burning any more time and picked up a 1 inch rattle gun from the pawn shop (brand new for 99 clams) and rented a compressor. Turned out or broke all the bolts except one whose head is rounded, and another whose head is rusted away. I'll blow those two off. Six out of the fifteen (one missing) came out ok with the torque set on 2 out of 3.
Next is to split the chains. Both master pins are of the equal size plug in each side version, and both have the inner side plug missing. Is there any chance that I can pound the pins out from the inside with the outside plugs in situ? If not, I'll need to gas axe those out as they're all messed up inside the plug
P.O. Box 9301
Peoria, IL 61612
(309) 691-5002
cat@acmoc.org
- Chris R
- Jason N
