- Thank you received: 0
Yes the 1693 was turbocharged & the higher HP ones were aftercooled & they were a 5.4" bore & 6 1/2" stroke which gave them 893 Cu.in. displacement. The 3406 was the same specs.There were various HP ratings but most were 325 HP turbo charged only & the high HP model with aftercooling too was 425 HP.I ran one on the dyno at work one time that I rebuilt & he had it set up a little & it put out 550 HP without any sweat & he wanted it left that way which I did. He hauled from coast to coast so going over the mountains out west he needed the extra HP he said. He drove it himself & took real good care of it & it had 880,000 miles on it when I majored it for a bearing that went out.I had done some in frame work on it over the years before the major overhaul.He was a local customer of ours but passed away at too young an age.Don,t know what ever became of his cab over KW. The 1693 was a dual overhead cam engine where the 3406 isn,t so they are totally two different engines the way they were made.
Rob, if that engine is set up for a high HP I,d have it set back to the 425 HP max. if I were you. The D343s had a big heavy rear bell housing on the engines used in equip. where the 1693 truck engine had an aluminum housing to cut down on weight etc.Also there were a few other small changes too so if you can I,d try and get the engine that came out of an OTR truck so it would be easier to install and set up.I can,t just remember if the real early 1693s had that big injection housing & governor on them like the early D343s had but try and find an engine with the smaller more compact housing on it.
P.O. Box 9301
Peoria, IL 61612
(309) 691-5002
cat@acmoc.org
- Chris R
- Jason N
