Truck Engine
17 years 6 months ago #3756 by Packrat
Truck Engine was created by Packrat
Good morning;
Seeing the post for the 1693 engine got me thinking. I'm considering restoring a 1950's vintage KW and I would like to use a Cat engine. What, if any, Cat engines were used in over-the-road trucks in that era?
Packrat
17 years 6 months ago #3761 by SJ
Replied by SJ on topic Truck Engines
In the 1950s years Cat wasn,t into truck engines till 1961 when the 1673 Truck engine came out & it was basically a D333 engine set up for a truck engine. The 1693 came out in 1964 & again was a reg. Cat engine used in equip. the D343 engine & was set up for truck use.It was their first really HD truck engine & was really a powerful engine in their day.I really fell in love with them from day one but the later truck engines were a little better on fuel & oil mileage. Packrat there should be some around yet for you to purchase & I don,t think you can go wrong putting one in your truck.
17 years 6 months ago #3765 by Packrat
Replied by Packrat on topic Truck Engine
Thanks SJ, that's what I was looking for.
Packrat
17 years 6 months ago #3789 by OzDozer
Replied by OzDozer on topic Truck Engine
Cat produced their first automotive style truck engine in 1939, with the release of the 6 cyl D468, a modified D4600. They introduced a 4 cyl version, the D312, in the following year, 1940.
Neither were a commercial success, as they were too heavy (being crawler engines originally) .. power steering was unheard of, and the weight of the Cat engines made truck steering a chore .. plus gas was still cheap and plentiful, and the gas engines were substantially cheaper to buy and overhaul.
WW2 production demand re-alignment, saw the D468 dropped from production in 1942, and the D312 in 1943.
Only a few hundred of each automotive engine were built.
Cat did not produce any automotive-type engine again, until 1961, with the introduction of the 1670, the 1673, and the 1693 models.
Cummins had the ascendency for truck diesel power in the 1940's, and 1950's, with Detroit Diesels making inroads into Cummins market share in the 1950's. Cat did not make a serious assault on the truck engine market again until the mid-to-late 1960's.
17 years 6 months ago #3796 by Dozerman51
Replied by Dozerman51 on topic Truck Engine
Hi Oz, Have you got any pictures of the D468 and D412 engines you could share with the board. I would imagine both engines were direct electric start. If so, then why was direct electric start not available on crawlers and graders until much later?
17 years 6 months ago #3799 by OzDozer
dozerman51 - Yes, the Cat automotive engines were electric start, and the marine engines were also mostly electric start in the mid-to-late 1930's.
The marine electric start system is understandable, as the temperature extremes in that application would not be as large as on land.
However, the Cat automotive engine engine was equipped with a 24V starting system, and a 12V lighting system (a not-entirely-satisfactory, and complex system, that has been used by European and Jap truck builders, and which I have plenty of personal experience with .. :( ) .. and the D468/D312 user was warned, that the electrical starting system was designed only to start an engine in good mechanical condition, and at temps of 50°F and above.
Cat warned that ''some provision will be required to heat the engine to the above temperature for satisfactory starting'' .. and the Cat truck engine owner was left to his own devices to figure what that heating system might be .. on any particularly bitterly cold, Winter night, or morning .. :rolleyes:
Another nail in the coffin, of Cat truck engine sales, in that era .. :(
Armed with that warning .. it's easy enough to see why Cat, and many owners, much preferred the pony start for the crawlers and graders in the 1930's to 1950's.
With the poor quality batteries .. that were heavy, and had low cranking output, in that era .. the pony start definitely had many advantages for starting tractors in the extreme cold of the North American and Canadian winters ..
You didn't have the problem of battery failures, which was a lot more common in the 1930's and 1940's .. plus, with a pony, you could leave a tractor for months, and come back and not have to worry about charging flat batteries ..
Here's a pic of the D468 .. I have not yet found a pic of a D312.
img249.imageshack.us/img249/4581/catd468gi5.jpg
The D468 commenced production at S/N 1N3001. It featured an all-new 'automotive type' governor, a front mounted crankshaft vibration damper, a self-contained water pump with replaceable spring loaded seal, electric start, a choice of Midland air compressor, or Bendix vacuum pump (both, belt-driven off the rear of the gear drive generator), SAE bellhousing with a Spicer single plate clutch, and a Spicer 5 speed overdrive transmission.
The "new type automotive governor" must have been a relatively poor design .. because only 73 engines were built, before a new design governor appeared in Jan 1941. This new style governor was also fitted to the D312.
17 years 6 months ago #3800 by Dozerman51
Oz, Thanks for the explaination and the picture. I see that there was probably not a fuel pressure gauge mounted in the cab of the truck.
17 years 6 months ago #3802 by SJ
Packrat you were only interested in an engine to repower your 50s KW so the old antique D312 & the D468 wouldn,t be what you,d want in it.I never even saw one but have some specs. on them & the 312 was only a 60 HP engine & the tops for the D468 was 100 HP.Also the 1670 was the old D330 4 cyl. engine also used in equip. but was setup for a light truck engine . They were only rated as a stop-go engine & for inter-city duty so it wouldn,t be for a KW HD truck as they were only rated at 165 HP tops for it.The 1693 didn,t come out for a couple years after the 1673.Packrat the 1693 engine would be what you,d want or even the little later 3406 that replaced the 1693 as both were used in the KWs.
17 years 6 months ago #3820 by Packrat
Thanks SJ, my last KW was a 1985 W900 with a 3406 which was a great truck. Sadly, I sold it in 2003. I want to do another one for hobby only and would like to go back at least to where they had round headlights. The 1693 intrigues me so a 60's era KW may be in order. What was the bore and stroke of the 1693 and was it turbocharged? I appreciate being able to tap your vast knowledge. Thanks.
Packrat
17 years 6 months ago #3821 by SJ
Replied by SJ on topic 1693
Yes the 1693 was turbocharged & the higher HP ones were aftercooled & they were a 5.4" bore & 6 1/2" stroke which gave them 893 Cu.in. displacement. The 3406 was the same specs.There were various HP ratings but most were 325 HP turbo charged only & the high HP model with aftercooling too was 425 HP.I ran one on the dyno at work one time that I rebuilt & he had it set up a little & it put out 550 HP without any sweat & he wanted it left that way which I did. He hauled from coast to coast so going over the mountains out west he needed the extra HP he said. He drove it himself & took real good care of it & it had 880,000 miles on it when I majored it for a bearing that went out.I had done some in frame work on it over the years before the major overhaul.He was a local customer of ours but passed away at too young an age.Don,t know what ever became of his cab over KW. The 1693 was a dual overhead cam engine where the 3406 isn,t so they are totally two different engines the way they were made.
Time to create page: 0.184 seconds
