- Thank you received: 0
Pump suction line? I was thinking the suction was coming from internal on the transmission pump. where is the line you are referring to?Sounds like you are getting someplace with it now. I like the pressure you are getting. Go after the pump suction line, might have a hardened up piece of rubber hose that needs replacing. Fix the cooler leak too, it's not causing your problem just making a mess. If you can get the tube out the side and fine but I think it's okay with the pressure you are getting now. Work on the suction line and stop the gauge vibrating. Then get it warm and see what the pressures do at low idle.
Later Bob
P.O. Box 9301
Peoria, IL 61612
(309) 691-5002
cat@acmoc.org
- Chris R
- Jason N
