- Thank you received: 103
For me, I found removing the gas fuel bowl allowed the easiest access to remove the 2 nuts holding the carb onto the starting engine. Remove the 2 screws that hold the bowl on, and gently pull the fuel bowl horizontally as mentioned earlier. You can see the corroded long brass jet tube that connects the bowl to the carb in my photo (photos posted in reverse order) I had to replace my jet, it was toast, the jet is still available. Once all cleaned up and all passages cleaned, (there are good posts in the forums on how to clean the passages) I reattached the carb body and then reattached the fuel bowl right on the starting engine.
This is good information. In the fifty plus years I have owned D2-D4 Cats I have been able to avoid removing a carburator, always been able to clean in place..
P.O. Box 9301
Peoria, IL 61612
(309) 691-5002
cat@acmoc.org
- Chris R
- Jason N
