D4 7U starting engine carburetor
Thank you received: 6
2 years 7 months ago #235282
by EliG
Are there any tricks to removing the carburetor on the starting engine? Pull the dash or the magneto to get to the lower bolts? For some reason the manual I purchased is missing the entire section on the starting engine and I can't get the entire manual in the library to load completely.
Thanks!
Fat Dan
Thank you received: 90
Thank you received: 44
2 years 7 months ago #235287
by GrantJ
I had the carb off of my 6U a couple of times recently. After fighting with the nuts, I removed the governor to get to the outside bolt. Cat did not make it a user friendly job. Crows foot wrenches are needed for the inner nut. Fun, fun ,fun! Grant.
2 years 7 months ago #235297
by Busso20
The easiest way I found was bonnet off, governor off a couple of different brands and types of spanner/wrench and wedge them in to make it happen, 1/4 or 3/8 drive socket if inner nut is tight next to mag, it will only crack it then go back to spanner/wrench, the linkages are reasonable to access, yes a few harsh words the first time around then its not to bad there after.
Fat Dan
Thank you received: 103
2 years 7 months ago #235336
by Fat Dan
They all have great ideas like extensive expletives ... they really do help. I'd like to add to the crow's foot tool and an old distributor wrench 1/2"- 9/16 has that funky s shape to get in odd places.
On my No.12 Motor grader's pony I had to remove the fuel bowl to get to the one nut.. Use caution with the long needle jet
Once off they are off simple carbs to work on
Good luck
ACMOC Membership
2 years 7 months ago #235337
by Fat Dan
I did find some rebuild kits for the 10hp pony one ebay
ACMOC Membership
steve_s
Thank you received: 387
2 years 7 months ago #235375
cat still have gasket kits for those carbs.
ours needed new butterflies too.
check the choke and throttle shaft bores for play if loos either have them machined for bushes or add a o-ring to each end to make a seal the wear can be a cause of hard starting.
the best way to clean them is to sonic bath them. it's worth the $ at the local mower shop to get it done.
Fat Dan
2 years 7 months ago #235405
by EliG
Thanks for all the suggestions. I got side tracked and haven't had a chance to get back to working on it. I bought some cheap wrenches and am going to creatively adjust them to get to the nuts.
2 years 7 months ago #235406
by Fat Dan
Thanks trainzkid88 that's good to know ... I had gotten mine before I knew how to SIS over on Cat.com
ACMOC Membership
Thank you received: 5
2 years 7 months ago - 2 years 7 months ago #235420
by outbackrider
For me, I found removing the gas fuel bowl allowed the easiest access to remove the 2 nuts holding the carb onto the starting engine. Remove the 2 screws that hold the bowl on, and gently pull the fuel bowl horizontally as mentioned earlier. You can see the corroded long brass jet tube that connects the bowl to the carb in my photo (photos posted in reverse order) I had to replace my jet, it was toast, the jet is still available. Once all cleaned up and all passages cleaned, (there are good posts in the forums on how to clean the passages) I reattached the carb body and then reattached the fuel bowl right on the starting engine.
Time to create page: 0.196 seconds
