- Thank you received: 187
Why bother with a relief? The cyinder is able to handle 10000 psi. If you are only going to be pressing upto D4 tracks apart, you're not going to get anywhere near the maximum. If the cylinder had heavy rust pitting or something then I would be concerned but it looks like it only as some surface rust. I would ask the local hydraulic shop to proof test it to be sure but it should take 10000psi without any issues externaly. Internaly it may be different, depending on what type of seals they used. Any seal other than piston ring type seals would most likely have perished from sitting so long. The bore may need a hone as well especially if it has been sitting empty of oil.have a relief valve in the line set to 5050
At no stage was I suggesting that you run without any relief at all. I was pointing out that an additional relief set to 5050psi was an unneccessary addition.i like the idea of a safety pressure relief of some type...unless Safety is like 5th, 6th, 7th priority..
P.O. Box 9301
Peoria, IL 61612
(309) 691-5002
cat@acmoc.org
- Chris R
- Jason N
