- Thank you received: 187
Using a power pack with that cylinder will not be a problem. Finding a power pack that is capable of 10,000psi will be the difficult part. That sort of pressure usually requires an Enerpac or similar power pack which could be quite pricy.even if you had to rekit it with all new seals its worth getting. i would caution you about converting it to power pack drive as the unit may not handle it. seek the advice of a hydraulics shop first. so you could match a suitable power unit to it.
P.O. Box 9301
Peoria, IL 61612
(309) 691-5002
cat@acmoc.org
- Chris R
- Jason N
