- Thank you received: 341
Yes thank you all for the tips. I didnt get to work on the old iron today. It may be the last chance to take the family out in the tinner before things get too cold so we did that today. I dont think the governor was holding it out but good point to check it over and give it a little maintenance. My Cat has a plastic tank off a snowblower, 1/4 and 5/16 fuel hose, a see through Fram inline filter and I rigged a brass 1/4 turn valve. I will check fuel flow at the carb. I did clean the fitting into the bowl, float valve. There shouldn't be anything hiding there but I will check again. Would any of the passages in the bowl give the symptoms I noted? The rest of the carb I went over thr other day. I pulled the metering jet tube and blew it all out, inspected. All looked pretty good.
P.O. Box 9301
Peoria, IL 61612
(309) 691-5002
cat@acmoc.org
- Chris R
- Jason N
