- Thank you received: 67
Since this seems to be problematic in quite a few older Cats and the fact that many of them clear up after hard running under load, I would think that the rings are stuck in their lands due to gummed up fuel & oil. Only after sufficient heat is generated through hard load do the rings break free and start sealing again. D4 Angelo's D2 has this same issue and after working it hard it did quit slobbering, but after hours of light use (idling and parades) it again started slobbering.
Thoughts??
P.O. Box 9301
Peoria, IL 61612
(309) 691-5002
cat@acmoc.org
- Chris R
- Jason N
