- Thank you received: 9
Very nicely done!
Alternatively a bolt with a longer unthreaded shank might be used so that there was only just enough threads for the nut to tighten down on top of the rod end ball.
And they are cheap too. Only about thirty dollars each. I am not sure if you can get boots for them. They are up under the engine so they should stay relatively free of the heavier dirt and gravel etc.Hi Phil,
I echo what CCJ has said.
I hope you can get boots for those Rose Joints to give them a chance of longevity--if not then at least, with your adaptions, they will be easy to replace--clue is to not run them too long when worn as this will help keep shock loading due to excessive end play in them to minimum and so save the rest of the system from being over stressed and so requiring all this to be repeated.
Nice well executed work.
P.O. Box 9301
Peoria, IL 61612
(309) 691-5002
cat@acmoc.org
- Chris R
- Jason N
