944 bell crank repair options
4 years 3 months ago #218592 by PhilC
Hello All
The ball joints on my 944's bell crank are completely worn out. There is up to 1/2" of play in one and 3/8" play in the other. There are no available spares from Cat. To make matters worse it has been repaired before but very poorly. It has been welded before and test drilling confirms it is not cast iron. I am thinking of using a ball joint rod end (like this one) and welding a bolt in the hole the old ball joint was in. The old ball joint had a 15/16" UNF thread so if I go to a 1" bolt it should be as strong as the old one. The amount this machine will be used I doubt the rod end will come loose. Does anyone have a better idea or know where I can source weld in tapered ball joints?
Also the ball joint tapers at the wheel end of the tie rods have been loose for some time so the holes are elongated. The actual tapered shaft on the ball joints are still fine. I want to fill the holes with weld and drill them out and ream a taper. I think the taper is 10:1 or 5.71 degrees, can anyone confirm the taper Cat uses?
Regards
Phil
4 years 3 months ago #218594 by ccjersey
If at all possible, I would drill the hole and put a bolt through instead of welding it. I would be afraid of the welded in bolt snapping off at the edge of the weld. I guess if that happens you could drill it out at that time.
Have you checked aftermarket sources? I don’t have a parts book for the 944 but if you want to post the numbers, I’ll look. Our 944 needs the same treatment but the owner doesn’t really care that you can’t travel in high range high gear. I was able to source the needed joints for my 922b and it’s tight now.
4 years 3 months ago #218597 by PhilC
Replied by PhilC on topic 944 bell crank repair options
Thanks for the reply ccjersey and that is a good point. I will machine up a couple of bushes and weld them in. Then the bolt will not be heat affected.
Yes but only in Australia and on ebay.
I would need to replace the entire bell crank assembly to be able to fit new or used OEM ball joints and seats. Bell crank part number is 4K2861. Stud part number is 4K3792. Seat 3K5181, ring 2K5340, spring 2K5335 and the plug 2K5334.
Regards
Phil
4 years 3 months ago #218633 by edb
Replied by edb on topic Truck Components
Hi Phil,
ball studs may be the same as Mack, Kenworth etc. TRW may have something but I feel they are car market stuff.
I would check with a decent truck repair place and see what they offer.
The bell crank should be cast/forged steel and so would be weldable, as long as it is not going to be used on the Highway, using correct pre/post heat procedures with low hydrogen rods.
It is a tough one to repair as the wallowed out bell crank bores are part of the ball stud housing as there is no room for a standard ball stud anchor nut to clear the other components.
Maybe even cut the damaged ball stud hole ends off the bell crank and weld on new sections machined to suit standard ball stud components by using just the ball stud, spring etc--the weld on sections would need to be machined to suit the dimension of the discarded new ball stud casing so that the lock ring, spring, cap etc fit the newly machined replacement ball stud hole--sheesh.
Trying to recall if we did some this way at The Dealer--way back before welding steer components was outlawed and Highly Illegal now--for good reason if not done correctly.
A few charts for heavy ball joints :-
www.bareco.com.au/files-tierod-un2
4 years 3 months ago #218671 by ccjersey
Looks like you need a couple of very large suspension ball joints instead of rod ends.
O in
I guess the most important part would be to get ones with the tapered stud correctly sized for the tie rod socket and then worry about installing a bushing by welding or otherwise in the bell crank to accept the socket end of the unit.
4 years 3 months ago #218685 by ccjersey
If you’re looking for a Tie rod end to use the Bareco B5559 JD replacement is listed as 23.6 mm diameter at top/thread area and 26.5 mm at bottom of taper. I haven’t seen anything else anywhere that big but I am a bit cautious that those dimensions are a misprint because the JD part number they interchange with seems to be on some pretty small tractors. But I have no personal experience with any of them so maybe that’s really how big the stud is.
Another idea I had and what I would probably do if I had to do something quick and dirty would be to “pour” a bearing cup in the bell crank using molten bronze or a hard babbet around the best ball stud I could come up with. It would certainly not hold up as well as the original but should last a while and take all the slop out. Might even pour it around the existing bering shell if it fits the ball at all well.
Another idea I had is to retrofit the tie rod and belcrank to use the ball stud and bearing from the outer ends of the tie rods. I believe those are still available as I got an aftermarket set a couple years ago. I’ll try to remember to look tomorrow to see if that is even somewhat of a possibility.
4 years 3 months ago #218843 by PhilC
Hello ccjersey
Thanks for the ideas and the info. The tie rod ends are not available any more from Cat 4K3597 (Part number not found). I don't think mine are original as they do not have a Cat part number only the part number shown in the above pic.
At some stage there has been major mods done to the links and the bell crank. The links shown in the pic should both be the same length. This is the cause of the loader having very bad toe in and also it steered more one way than it did the other way.
Eddie it is too late for the welding as you can see in the following pictures. Very poor welding too. Don't worry, this old girl will never be on a highway nor even a sealed road, at least not while I own it.
At this stage I am going to go with the ball joint rod ends with a bolt through the bell crank and rod end. I cannot find any suitable ball joint replacement here in Australia. No website that has something that looks suitable lists the thread dimensions. I don't think there is enough clearance to use two outer tie rod ends especially since one tie rod would be overlapping the nut from the other rod end.
If at a later date I find something more suitable or the rod ends won't stay tight then I can easily change it then. Ideally I would be able to find a press in ball joint of the correct size.
According to the info I got from Cat about the link the correct taper is 1.5 inches per foot which is 7.15 degrees so I was way out with my measuring:)
Thanks for the ideas.
Regards
Phil
4 years 3 months ago #218856 by ccjersey
Those are really buggered!
I can’t imagine that the spring usually found inside a unit like that wasn’t ruined by the heat of welding them in. I expect they didn’t last nearly as long as normal.
What could they have been thinking on the tie rods? Theft prevention? Couldn’t go very fast getting away!
I replaced the ball stud and bearing on one of the tie rod ends a couple years ago. Seems there were some small parts of the assembly I didn’t/couldn’t get but I put it together as best I could and it steers pretty well. Keeping it in my lane on the highway keeps me busy at top speed but it’s possible. Had to make a run just at dark the other night to shove a tree out of the highway after a storm. That’s the longest drive and the highest speed I’ve taken it up to since I worked on the steering.
Good luck with the 944, I don’t think there’s any way but up from it’s present condition!
4 years 3 months ago #218876 by edb
Replied by edb on topic Rose or Heim Joints
I wonder if large Rose/Heim joints in say 3/4" and up sizes would work--not sure if seal boots are available for this size but would be easily replaced and simple to fit with Grade 8 Cat bolts as I am sure longevity would be marginal--cost etc. would be a factor too.
www.mcgillmotorsport.com/3-4-x-3-4-right...formance-rod-end-36/
4 years 3 months ago #219446 by PhilC
Hello All
Sorry for the late reply. I have fixed the bell crank as best I can given the parts availability. The ball joints had been bored out before so all I had to do was oxy out the old ones and machine a new bush up to take the alternative ball joints.
So far I have done the following;
Bored out the bell crank main bore.
Machined new oversized shaft.
Removed old ball joints and machined bushes up to retrofit the new rod ends.
Machined new link bars from the wheels to the bell crank to take the new rod ends (And to reset them to the correct length.)
I have the following still to do
Weld up the holes in the hub mounts and re-drill and ream them to the correct taper.
Inspect the rest of the link bars from the steering box to the bell crank. One has been bent and re-straightened but I think it is now too short.
I have tensioned the bolts up to as close as I could get to the correct torque for a 1" UNF grade 8 bolt but I expect it will eventually come loose. The tapered ones do:)
Regards
Phil
