- Thank you received: 63
Thanks for the reply ccjersey and that is a good point. I will machine up a couple of bushes and weld them in. Then the bolt will not be heat affected.If at all possible, I would drill the hole and put a bolt through instead of welding it. I would be afraid of the welded in bolt snapping off at the edge of the weld. I guess if that happens you could drill it out at that time.
Yes but only in Australia and on ebay.Have you checked aftermarket sources? I don’t have a parts book for the 944 but if you want to post the numbers, I’ll look. Our 944 needs the same treatment but the owner doesn’t really care that you can’t travel in high range high gear. I was able to source the needed joints for my 922b and it’s tight now.
P.O. Box 9301
Peoria, IL 61612
(309) 691-5002
cat@acmoc.org
- Chris R
- Jason N
