d47u corona jet
d47u corona jet
Thank you received: 6
4 years 5 months ago #216266
by nomorejohndeere
Good morning
Zenith carb on d47u pony
I've pulled my carb off to do a cleaning
When I pulled the main jet(float) out there was a ring around the jet near the tip that broke up and fell off of it.
I don't know if it is part of the jet or crud that formed a ring.
Does the jet have a ring, made of some material other than metal that is part of it? To facilitate sealing...
Thanks fellas
D47U
AC HD3
nomore JD1010
nomore IH T340
4 years 5 months ago #216268
by jstandle
The screw in jet has a washer between the jet and the carb body for sealing. A new one will come with a carburetor kit.
Make sure you clean that lower passage real well, sometimes its best to remove the lead blocked passage (replace with a BB) to get it thoroughly cleaned. Also, check/adjust your bell crank back to 90*. Do some searching on here, carb cleaning/tuning discussions have been covered well.
Jordan
Thank you received: 13
4 years 5 months ago #216272
by blwatson
When I did my pony carb on my D4 the thread "Pony Rebuild in Progress" started by Jw74 0n 03-04-2014 was very helpful and can be found by doing a search. I do not know how to attach it here or I would. Very good pictures. I found that a .17 cal lead pellet also worked good for replacing the drilled out plugs.
Bruce
D47U #11867-1950
Idaho
4 years 4 months ago #216492
by nomorejohndeere
I should have said needle instead of jet
It's all steel...is it supposed to be? Is this an original needle?
Many replacements have a different color tip I assume made out of a different material.
When I turned the jet upside down to drop the needle out a small round hunk o stuff came out with it in pieces. My eyes can't tell if it was a part of the needle or just solidified crud.
If it's crud then that lower passage has to be clogged.
D47U
AC HD3
nomore JD1010
nomore IH T340
Thank you received: 142
4 years 4 months ago #216499
by jstandle
Looks like the crud that came out is what was left of the rubber tip on your needle. The original needles were all metal but that is not an original, that one would have had the rubber tip.
The cheap harbor freight ultrasonic washers work good for cleaning these carbs, strip it all down and give it a real good cleaning. A carb kit will include a new needle and jet.
Jordan
4 years 4 months ago #216535
by nomorejohndeere
Thank you
I didn't know for sure.
I will order a kit, need gaskets as well.
Anyone with a favorite supplier ?
I do have a heated ultrasonic cleaner, what's your favorite solution?
D47U
AC HD3
nomore JD1010
nomore IH T340
Thank you received: 103
4 years 4 months ago #216538
by Fat Dan
eBay had some kits. 30M
I took my carb apart and the tip on the float jet had hardened an cracked and when touched fell off.
ACMOC Membership
d47u corona jet
Time to create page: 0.192 seconds
