- Thank you received: 67
the flame doesn't have to get into each cylinder but the more the merrier. i guess you could install two if you thought it was needed.
-doesn't internal combustion require oxygen?
IF, IF, you can get ac current to the tractor, there are recirculating block heaters. they are 1600 watt. My dad had one on his cummins. Electric circuit out to the heater. In morning when he gets up he turns on the circuit. The heater hooked near upper radiator hose and lower block port recirculated engine water through the heater. By time he went out to start, the hot light would be on , on his dash panel.just wondering if there's better/different options available for pony motors nowadays...(besides 24volt)
-i know there's guys that would never stray from original...and that's okay...but that's my most recent brainfart....what if...
You need to idle the pony for a while before putting it under a load. Splash oil system takes a while to get oil into the pony bearings. Most folks don't do this either.MY dozer is apparently too old for glow plugs without doing some serious modding.
I think there are some screws on the side of the cylinder head that help cinch the pre-combustion chambers in place. I have wondered if a person could remove that screw and drill through the pre-combustion chamber and thread it to hold a glow plug. Just, it may be a bit of a problem to re-align the drilled hole if the pre-combustion chambers needed removed and re-installed for some reason.
There are also block heaters that heat up the radiator fluid to help generate heat for starting. Though I think the block heaters don't exactly heat very fast. With the exception of glow plugs or ether, I think a pony is generally the fastest way to get the engine started in the coldest of conditions. Probably 5-10 minutes.
I think part of the reason ponys tend to be most beat up is the fact that there is no starting engine for the starting engine. The pony basically starts working cold and then warms up and gets all the fluids flowing at start, while the diesel gets to enjoy having the pony doing all the work to get him ready to run.
I do kind of wonder what the engine life is of a pony start diesel over the more modern electric start diesels are that never had a pony. I believe the most wear comes on an engine when it is cold, so many diesel engines without a pony are basically starting cold and running cold for a little while.
P.O. Box 9301
Peoria, IL 61612
(309) 691-5002
cat@acmoc.org
- Chris R
- Jason N
