JM --
Biggest tip I can give you - LET SOMEONE ELSE DO THE PINS & BUSHING WORK! Not a job to be done without proper training, all safety precautions and properly operating equipment designed for that purpose with proper tooling and tested relief valves! Not a job for the improvised or unequipped shop. NO OBSERVERS, distance is safety!
The pressures it takes to remove pins and bushings, pull sprockets, etc on "our" Cats and other heavy equipment are measured in TONS!
The press I was operating had seen a lot of use, worn tooling and uneven feed table on uneven floor did not help either. All parts were handled by "armstrong" power, stacked on the floor as taken apart and then returned in same order as removed. Same link, pin/bushing were maintained throughout the process. The bolts were removed on only one side of the plates, so one rail section was always attached to the track plate. If the bolt could not be removed with the 1" drive impact wrench, the head was cut with Victor Wrench and scarfing tip.
I had the misfortune of being behind the controls when a ram failed or should I say EXPLODED!
Very fortunate no one was hurt other than scared and some hot oil thrown on us. 4 fifty-five gallon drums (that were our waste bins for pins, bushings) were flattened and knocked off the pallet alongside the press. They were about 1/4 filled, so not exactly light. (Press ram cylinder wall was about 3/4" thick! Dia approx 6-8 inches from memory) Amazingly, the street-el and hose remained intact on end of the cylinder housing. (I had just finished a set of D8 tracks, retooled to D4 and was half way through the first set of rails when this happened)
A "New" ram was located, ordered and installed - and a few months after I had left the shop, my brother-in-law was operating the press --- same thing happened to same end. Lucky for him, I had built some "guards" from 3/8 thick x 6 inch channel iron - saved him!
Who knows what was wrong, obviously a relief valve had failed or cylinder had a flaw. Either way - it was a catastrophic failure! (no records, no test data, without such, no way of knowing if the relief valve, pressure gauge were actually operating to specifications)
For those thinking this was an independent "fly-by-night" shop --- no - it was a Caterpillar Dealer!
Those pressures to push pins and bushings from the rails can be very extreme, when they do let go, you do not want to be in the way!
As far as breaking bolts holding the plates to the rails with a sledge hammer and cold chisel - in my opinion - that is flatly out of the realm of practical or safe. Many have lost eyes, some killed by flying pieces from the striking object or the struck tool! The "mushroom heads" on struck tools have injured and maimed many - well documented.
Working on or with equipment is inherently hazardous - one must use all precautions and follow proper procedures. Accidents do not happen - there is a cause.
Please think about the consequences before you become as statistic - practice safety and enjoy the hobby and joys of keeping the Cats going.
"keep 'em crawlin'"
CTS
