- Thank you received: 187
Here are some pics of one,
Various sizes....
Hello Mike,
I hope you are well !
I did many years ago change a set of D4 shoes from one set of chains to another, which involved removing all shoes from both sets of tracks.
In those days I didn't have a rattle gun so I bought a good quality (Britool) 3/4 AF combination spanner and used it with a length of pipe.
Not a single bolt defeated me although the spanner was banana shaped by the time I'd finished.
Even though the shoes had been on for many years, the (fine) threads on the bolts were clean and shiny when they came off, probably because they'd been pout on my Loctite or similar.
I'm afraid I can't help you with a picture of a trach wrench though. There is a schematic of one on the tools page in the parts book though.
Best Regards
Actually they fit both the hex nut and square nuts.
at The Dealer on smaller tracks like D4's etc where the bolts were not going to be reused we simply turned the tracks on their side and used a sledge hammer and suitable punch to shear the nut ends of the bolts off--a good sharp blow and one swing did the job--usually the tracks came in wound up on their sides so it was quicker and cheaper than oxy cutting off like was done for some D6, D7 upwards.
Often if the bolt heads were well worn a socket would not grip the bolt head and so there was no choice--track work was never easy and can be a demoralizing task.
P.O. Box 9301
Peoria, IL 61612
(309) 691-5002
cat@acmoc.org
- Chris R
- Jason N
