- Thank you received: 39
Received my 3R2315 to 3R3000, 1S1 to 1S5000 and 6S1 to 6S105 parts manual. They all use a 19Pxxxx pump. I did see in the section showing the 3% governor that one cap screw 1D4538 is 2-1/4" going into the IP housing. That might be going into that blind thread hole at the end of the fuel gallery.
Josh....if you read this does the NPR show application for a 7B5191 cover or housing, whatever it is.
I am going to put this back together unless someone has some final idea about the threaded hole. Reviewing my SRB I see the photos below that illustrate the 2-1/4" bolt inserted OM may be referring to above. Nothing on my governor indicates it needs to be attached to the housing.
Thanks to all for the assistance-
Bernie
P.O. Box 9301
Peoria, IL 61612
(309) 691-5002
cat@acmoc.org
- Chris R
- Jason N
