- Thank you received: 620
Man! I have been a PITA on this one, but could not rectify what I was seeing. I did not see Eddies post until after I last posted.
I'm wondering now if when the block was repaired the fuel housing was replaced. If you recall the lower two nuts on the housing that lie against the block were missing. The hour meter assembly is odd too. Need to take another look at that also.
Any expectation that the governor is a changeout too? Or does the D42T governor match up with the 4G housing? Also, is the 25P535 stamp on the housing consistent with the 2T and 4G?
I appreciate the help-you guys are sharp and tenacious.
Have Fun-
Bernie
Hi bernie,
seems to me if you removed the outer plug and seal then the threads would be part of the main housing and if they go thru to the fuel gallery it indicates that a long threaded bolt could be used to force the outer plug out via the fuel galley--easy to say now that we can see the threads.
Other than that I have missed the point and so not understand what you are trying to achieve--if the inner threads do not go thru to the fuel gallery--if they do then they would likely be utilized to push the outer plug out.
As a starting point for Shut off problem I would begin externally at the operators station Stop lever with the adjustment of the linkage rod length to get the lever back in to its effective operating range.
I stand to be corrected.
P.O. Box 9301
Peoria, IL 61612
(309) 691-5002
cat@acmoc.org
- Chris R
- Jason N
