- Thank you received: 0
You will need to provide block casting numbers, serial numbers of engine and machine or probably more likely arrangement numbers for the two engines to get much specific help.
The 60Axxxx series uses as D330A engine 5-1/2" bore.
The 2Bxxxx series (D330C 5-3/4" bore) is an industrial engine.
It is my understanding that these are entirely different engines that do not interchange. That being said I'm certainly not the last word on what can be cobbled together.
Big difference between the two is how the engine is mounted. The Industrial Engine is four point rigid mount, the Vehicular Engine mount is three point with a rubber flex bushing mounted to the front cover. Attached pictures of the Industrial Engine front cover and a variation of the Vehicular Engine mounting.
Yup, got my fives mixed up with the fours, thanks eddie.
Just about everything on the D330c Industrial is different than the D330a vehicular engine. Flywheel housings are different as well but I see the housing to engine gasket is the same 9H5921 part number so they may interchange. Front engine support is different for the two engines but you may be able to work around that. Be interesting to see how this project works out. Please keep us posted.
I feel OM has had one of my Seniors moments like I suffer often and mis-quoted the D330 engine bore sizes as 5.5" bore and 5.75", but I would be sure he meant to write 4.5" and 4.75" bore sizes for the respective D330 engines.
P.O. Box 9301
Peoria, IL 61612
(309) 691-5002
cat@acmoc.org
- Chris R
- Jason N
