- Thank you received: 39
I think your sentence “Two of the bolts for the main engine inspection covers are removed and therefore not obstructing the movement of the Pinion Clutch assembly.” might just have helped me enormously. I got the governor off having finally found that pesky bolt a third of the way up on the engine block side but couldn’t budge the pinion clutch assembly. It would only move a tiny amount. I’m away at the moment but hopefully if I can get those bolts you mention out that will help. I’m loathe to pry too much for fear of cracking the housing.. My pony is removed at the moment so I thought it should be straight forward to check the latches as per Squatch253’s video..
....what are thoughts on the end plate (Cage) at the front of the Clutch housing? Can this be removed on the tractor with governor on? I with idve put a small puller on it, maybe even a battery post puller using the end hex but as the leverage point. The assembly would practically fall out with that plate off.
Appreciate your feedback- Bernie
P.O. Box 9301
Peoria, IL 61612
(309) 691-5002
cat@acmoc.org
- Chris R
- Jason N
