Fitting an Alternator to D4 7U
Thank you received: 53
4 years 9 months ago #208677
by bboaz
Drujinin yes I made the pulley. Mounted the roughed out aluminum pulley to the water pump pulley and did the final machining so it would run true with the fan pulley. Also put square holes that would fit a 3/8 inch ratchet in the aluminum pulley to help turn the original pulley to tighten the fan belt. Made the bottom mount for the alternator wider and used spacers to compensate for belt alignment after the fan belt has been tightened. I will use the original generator mount to run a hydraulic pump for blade control. bboaz
4 years 9 months ago #208694
by drujinin
As far as the fan on an "SI" alternator, the fan is not uni-directional as Neil suggests. I believe there is someone who makes the fan for opposite rotation, just can't remember where or who?
4 years 1 month ago #221297
by cat5u
Hi Lance I have a D4 30A that has a 24v starter fitted but no way to charge the 24v batteries and I was wondering what system you ended up installing on your 7U?
I don't have a 6v or 12v generator or the housing on my engine.
Does anyone have a generator/ housing and drive gear for sale in Australia - I am in Sth Aust?
Thank you received: 409
4 years 1 month ago #221298
This doesn't directly answer your question but it might be an option to install a series-parallel switch if you find a 12v generator for the machine. The preference would be for the 24v generator as you described but if you can't find one and can find the 12v generator, then this would get you charging with just addition of some wiring.
Thank you received: 153
4 years 1 month ago #221308
by rax200
Hi cat5u,
Have you tried Tillys in Toowoomba or Paul Moore in Toowoomba, i have listed the 24v gen by Cat part number mansfature part numberand the regulaters as well
5H0772 GRC2418C214 24V 18A 3L3156 RGR2418C214
9H1324 RGR2418C114
1S0151 1105235 24V 20A 5L6614 2M6497 1118793 VR150
1S0151 1105241 24v 20A 5L6614 2m6497 1118793 VR150
Regards
Daryl
1937 RD4 4G4368
1940 D4 7J3717
1942 D4 7J9915SP
1942 R4 6G2550SP
1944 D4 2T6584SP
1945 D4 2T8978SP
1946 D4 5T6271
1956 D4 7U37855
1954 DH226 S/N 89 Howard Tug
Time to create page: 0.147 seconds
