D2 cat pulling to the left
4 years 10 months ago #208107 by nhra6284
Ok, so I finally got the D2 I have been working on to run decent. Now, it pulls to the left when going down the driveway. Gets worse the more load you put on it (grading gravel). Both side brakes and clutches work just fine. The only thing I can see is the right track is tighter than the left. Would that make this thing pull to one side?
4 years 10 months ago #208109 by JackD6-5R
My D-2 Pulls to one side, but the one track is worn more than the other. Tracks from2 different machines.
D4D D65R D73T 933C HT4 955H Gardner Denver comp.318 Cat.
4 years 10 months ago #208111 by STEPHEN
Replied by STEPHEN on topic D2 cat pulling to the left
Left clutches could be slipping. I guess you know that the steering lever needs some free play to account for future wear?
4 years 10 months ago #208173 by Duane
Replied by Duane on topic D2 cat pulling to the left
My uncle bought a D4 in the 1970s brand new. It has been mostly used for dozing in decent conditions, good farm dirt, not much rock.
As long as I can remember, it has always traveled off to one direction when roading. Traveling down the dirt and gravel roads, I would get the scheme worked out to aim at the far side of the road at some not too distant point, and it would never leave the road. It would travel in a big arc, and then I would aim at the far side again. Very annoying. When working it as a dozer, no obvious problem. Pulling farm equipment, or grooming roads, there might be an issue. No slipping clutches, and as I recall I could never detect any obvious wear differences, all original undercarriage, never any major work done on the tractor. I would say it is still a low hour, low use, good condition machine. I wouldn't mind owing it.
Next time I get close to it, or run it, I will be looking again, i'm sure.
Your problem does sound like possible steering clutch slippage if it gets worse with increased load.
4 years 10 months ago #208177 by neil
Replied by neil on topic D2 cat pulling to the left
As well as relative track length, track roller frame alignment could play a part, even in a brand new tractor. Eddie B has some diagrams about track frame alignment. I thought I had saved them but can't find them. But basically, the frames should be parallel, perpendicular to the pivot shaft, the rollers, idlers and sprockets should all be in line, the track frames should be straight in both planes and not twisted, spaced the same width out from the tractor body, etc., etc. My D2 is all over the map so part of the r-n-r is to remove the wear and get the alignment right
4 years 10 months ago #208195 by tom
Replied by tom on topic D2 cat pulling to the left
Watch from the front when someone else is driving. See if the grousers slide one way or the other as the machine moves forward. Could indicate an alignment issue.
4 years 10 months ago #208221 by Duane
That all makes sense, and brings up some things I had not thought of.
Thanks!
4 years 10 months ago #208310 by catskinner
Replied by catskinner on topic Wandering
Yes, a too tight track on one side will make a difference in going in a straight line. catskinner
4 years 10 months ago #208312 by edb
Replied by edb on topic Undercarriage Alignment
data as mentioned.
4 years 10 months ago #208362 by neil
Thanks for posting that Eddie, much appreciated!
