3j1
3j1
Thank you received: 33
Thank you received: 50
6 years 6 months ago #180625
by hfdzl
Thanks for the link to 'Primitive Pete" that does take me back to shop class in the '60s. I have many examples of his work in the dooryard.
R2 5E3562 SP U.S.A. W.9151
R2 5E3563 SP U.S.A. W.9152
6 years 6 months ago #180626
by Garlic Pete
Sorry, 3J1Bill and HFDZL.
I studied that movie and took notes. Lots of good information in there. I'll try to do better from now on.
I am kind of proud of the fact that the flywheel nut didn't fall off, though. I must have did a pretty good job of pounding her on there last time.
I'm happy to provide you lots of fodder for restoration.
Pete.
6 years 6 months ago #180644
by 3J1Bill
What made this hole in the case? The hole appears to be pushed from the inside out. There is weld splatter on the inside and heat marks. It was plugged with a piece of metal and a bolt. Found two more welded spots on the right side. Bill
Thank you received: 409
6 years 6 months ago #180646
The other side of that wall is the chamber containing the steering yoke - I just removed my steering and I can't imagine what might have created those holes other than some kind of rough disassembly. I suppose the steering could have "blown up" but I'd still be surprised if it knocked a hole in that way. Another possibility is if it had a PTO on it at some stage and the shaft broke and flogged around.
6 years 3 months ago #185462
Wow that's quite the repair Bill, but it looks fairly kosher. I like that they saved it instead of heaving it out. Does it look like it's oil-tight?
6 years 3 months ago #186191
by 3J1Bill
I just picked up the completed pony motor fuel tank for 3J1 I had made in stainless steel. There will be no rust in the fuel for 3J1. Bill
Thank you received: 187
6 years 3 months ago #186207
by Mike Meyer
Very nice work there, that is what the Cat Twenty Two needs too, their main fuel tank is usually rotted out in the base.
Mike
6 years 3 months ago #186319
by 3J1Bill
I am ready to remove the motor on 3J1 and install a N.O.S. engine kit. Any ideas or pictures of a cradle or stand for the motor. I have done CAT 22's in the past with a heavy duty automotive engine stand, but this motor is a lot heavier. Thanks, Bill
3j1
Time to create page: 0.393 seconds
