Just refreshing this topic, I ended up buying a new set of rings from Otto 2 years ago, they were around $US235 from memory, but I'm still struggling to find the long sleeves needed, I contacted L.A. Sleeves 2 days ago and their longest sleeve in 4-3/4" bore is 12-1/4", which is exactly the same as I can buy here in Oz, so I'm now leaning towards using 2 pieces of sleeve to make the length.
The top of the 30 piston stops 2" before the top of the cylinder, and the top of the top piston ring stops 2-1/4" before the top of the cylinder, it looks like the bottom piston rings stops around 1/4" above the base of the cylinder. Most my old cylinders have been previously re-sleeved 50 or 60 years ago, and worn those sleeves out, and the big issue is when those sleeves were fitted way back when, the cylinder skirts were bored out to maybe 1/8" thickness, there is definitely no opportunity to cut a nice lip down there to support a new liner because I'm 100% certain the skirt will break.
Keeping in mind my old girls will be lucky to do 5 hours a year light work for the rest of their lives, can I look at fitting a short 1-1/4" long sleeve at the top of the cylinder, sitting on top of a 12-1/4" sleeve, to give me the 13-1/2" needed for the full length of the 30 cylinder? I realize it is not accepted practice, but I don't see any realistically priced option other than buying a heap of cast iron pipe and making new 13-1/2" sleeves, the join of the 2 sleeve sections will be safely above the travel of the top of the piston.
I know a couple of real nice Mechanics here in Oz who had quite a few old Cats over the years, one, a 20, needed re-sleeving and for some reason I can't remember, they used 2 pieces of sleeve, and the join was right in the middle of the bore, they might have run a bead of solder around the join.
Anyway they ended up selling that 20 to a guy who loved tractor pulling comps, and every time they went to a old machinery rally they would see the old fella on "their" 20 giving her a real hiding on the sled, expecting it to blow up at any minute, it never did.
If I was rebuilding a high HP high RPM engine with the aim of 10,000 hours hard contracting work ahead of me, my idea would be stoopid I know, but a old slow revving low compression Cat 30 producing what, about 10HP per cylinder at 850RPM flat out, for 5 hours a year, do you think it's worth taking the risk, I could always Loctite the short 1-1/4" section of sleeve in place just to help hold everything snug.
What do the Mechanics and Engineers think?
Mike
