D2 going in the shop
Thank you received: 183
4 years 7 months ago #212166
by d2gary
Got some work done on my canopy, like everything else just a lot of time, welding and grinding.
Thank you received: 620
4 years 7 months ago #212179
by Dan Pratt
Looks really nice. Great to keep the operator station dry(er) too when you have to store it outside. Are you going to do some logging with that machine?
You probably have a plan but I recommend reinforcement plates where it mounts to the fenders. They shake around a lot and will crack apart those nice rebuilt fenders without extra meat. Or rubber mounts.
Keep up the great work too!
4 years 7 months ago #212196
by 43gpw
Gary
Your an inspiration to all that look to restore yellow iron!
The pictures are worth a thousand word.
As with any restoration, a labor of love
Great work on the canopy/sunshade
What size is the square tubing??
Thanks for your post
Russ B.
4 years 7 months ago #212290
by d2gary
I'm not going to log with it just trying to put it back the way it was when it came to me. I'll probably pull some logs and push some brush with it but I have other machines for the real work.
I understand about the canopy mounts. The sweeps are hooked to the grill guard which is hooked to the radiator mount at the same connection point as the crankcase guard. The first mount on the fender is bolted through the bracket and angle iron reinforcements. The rear mounts are going to be bolted through the rod on the top of the winch. It's not a ROPS but it should keep rain and a wayward branch off the operator
4 years 7 months ago #212291
by d2gary
Gary
Russ B.
Thanks Russ I hope at least some of the pictures and information will be helpful to someone.
I used 2 in tube on the new canopy. The last one had 1 1/2 in pipe and looked ok size . I was afraid anything bigger would be out of proportion. The sweeps really brought the height of the canopy down.
4 years 7 months ago #212300
by rhartwick
Nice work. I was going to post a new thread asking for advice on constructing some sweeps for my D2, since I will be doing some brush clearing this spring and hate getting slapped in the face with thorn bushes.
When you get the chance, could post a few more pictures of the details of how you will fasten the front to the radiator guard? I hope to try to build something like yours, although mine will probably look like it was cobbled together compared to your beautiful construction.
4 years 7 months ago #212329
by d2gary
I can get some pictures of what I did. The grill guard on my tractor is bolted to the radiator shroud on the top and to the mounting point on the bottom which makes it pretty sturdy. You can hook to the bottom mounting point if your guard doesn't bolt to it.
The rear mount is where the problem is because it's just the unsupported fender that you need to hook to. If you dont have the winch to hook to you can hook to the draw bar mount.
4 years 7 months ago #212407
by d2gary
Here's a couple of pictures of my mounting points. I never really had trouble with the sweeps or the front mounts on my old canopy but the rear mounts tore everything else up.
The crossbar on the rear mount is what actually supports the back of the canopy, the fender brackets just add a little stability. If you have the crankcase guard it really stiffens everything up
4 years 7 months ago #212491
by d2gary
Little more work on the undercarriage. Following the Caterpillar literature I welded the shells to my first sprocket. I had an extra link from the tracks I'm using and tried them for fit, seems good.
Got everything but the roof on the canopy
Time to create page: 0.458 seconds
