- Thank you received: 620
Your absolutely correct!! those run at very high rpm. They can cut through a glove and your fingers before you know it! Hold on tight to those tools and use them cautiously.Speaking of safety.....
My friend’s cousin had a grinding disc come apart and took some pieces in his abdominal area
Was only wearing a tee shirt, lucky he didn’t bleed out, ended up getting stitches
So Wear your leathers, worth it and a face shield, and gloves
Leathers are hot, but well worth it
nice work you sure have been getting after it. one the cutting disk there great just don't buy the cheap ones. I love my 3m ones but I used jet, Norton, Walter. you may only pay 1.00 per disk more but you cut more and be happier doing it. safety side note full-face shields are a must with zip disks safety glass doesn't cut it. stay safe in the shop and keep up the good work
Martin, I see there's a couple of different thicknesses in the 3M cutoff wheels - 035 and 050. How to make the choice? I'm going to need to work on my track frames like Gary did.
Thanks guys. Gary did you prefer the grinder to the gas axe?
Now that I think about it, a chop saw with a steady for the work piece would be even more "dial-in-able". Hmmm, potential for a new tool to add to the collection....The torch definitely has its place for cleaning up previously added on treasures but for cutting clean metal the cutting wheel really is the way to go.
P.O. Box 9301
Peoria, IL 61612
(309) 691-5002
cat@acmoc.org
- Chris R
- Jason N
