D2 going in the shop
Thank you received: 620
4 years 7 months ago #211954
by Rome K/G
The 1F2297 bushings are $227.13 from Cat but not sure on availability. They are bronze material with internal grooves.
Thank you received: 183
4 years 7 months ago #211977
by d2gary
I'm sure I can find a couple over here but thanks for the offer Gary. I have a 4U back end I bought from Ron Meeder, which, if the sprockets are the same, would probably work. If I'm extra lucky, I might even have good percentage left in them. I'm betting those $50 bushings might be a lot more affordable than Cat. Could you let me know your source and the dimensions please.
I found a website called Bronzebushings.com. I just got a rough measurement for inside and outside to see what was available. I found 3 3/8 x 2 7/8 x 4 inches for $47. I would get an exact measurement but I think this is going to be a close match.
4 years 7 months ago #211979
by d2gary
Did a repair on the bell housing where the engine side panel bolts to. I purchased new side panels from another club member.
Had one roller that was really worn on the flange area so I built it up and ground it down. I was able to clamp the the roller down and get it to turn with the grinder wheel which did a pretty good job of smoothing out the weld.
Thank you received: 409
4 years 7 months ago #211980
Browsing that website reminded me that we fitted "nylon" bushings into the spring pivot on the Kenworth's six-rod suspension. Looks like they might sell that too
4 years 7 months ago #212043
by d2gary
I've been doing a lot of reading on the old Caterpillar literature on reclaiming and refurbishing undercarriage parts. After I had the sprocket gauge made it was pretty clear I had some work to do on my sprockets. My friend with the welding shop had some tooling already made to press the weld in shells for the sprockets. I gave him a template made out of a strip of scrap steel that I pounded out in the sprocket. The match isn't exact but with a couple of tack welds and some persuasion it should work just like the Cat documents say it will. This will save a ton of welding time. I read somewhere while doing my research that these shells can be replaced up to 4 times before the pins and bushings are needing attention. I am confident I will never wear these out.
4 years 7 months ago #212046
Hi Gary, apologies, I didn't get to my photos last night. Re: the weld-in shells, I think the only wrinkle that sometimes happens with them is if they're not in there good, the welds can crack and they fall out. I wonder if getting them hot and perfectly molded to each gap would help with that. In any case, that'd still be faster than building up with weld.
4 years 7 months ago #212047
by d2gary
Yes ,the Cat literature says to heat the shells and form them with a hammer. After making my template with cold steel and a hammer while holding it with a pair of pliers I dont feel like it's going to be a problem. If I have to a c clamp or a big pair of pliers should hold the shell in place.
4 years 7 months ago #212061
by timbo1946
Dad and i made shell out of pipe, been in there for 20 years or more. Cat only gets 5 to 10 hours a years so a cheap solution
Thank you received: 67
4 years 7 months ago #212063
by kittyman1
-yes a cheap solution for the sprocket, mostly time involved:clap2:
-what about wear on the bushing...any cheap fixes, ideas there to refurbish?
4 years 7 months ago #212165
by d2gary
Buy a parts tractor with decent tracks
Time to create page: 0.424 seconds
